gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 786
- 113
- Cincy Ohio
Back in June I broke a bunch of dog bones on my truck. I have since installed the 2 new DBs I had here already, and I ordered new inserts from Real Custom Trucks. Teds a great guy and met me half way to deliver. This was a project that required the use of a press to push out the old inserts and push in the new ones. I knew I wanted to drill and tap them before installation:
http://www.steelsoldiers.com/showthread.php?33684-Torque-rod-dogbone-mod-and-removal&highlight=
So I took care of that one weekend, the next weekend I found a 20ton press on craigslist and got to work. A buddy and I managed to get 4 swapped out in one night so that left 2 to do the following weekend. We(I) was smart enough to do the front bottom and top 2 while I had help, so the other 2 weren't too bad. After that, I had to fix the brake line. When my DB let go, the rear axle walked backward and let the driver side spring pack fall onto the brake line!
Today I decided it wanted to take her for a spin(its been sitting TOO long). I still haven't made the washers to bolt on the DBs but I can add those at any point since I've drilled and tapped the rod ends. I left about 8:30 and had so much fun I didn't get home till 11:15. While out and about I noticed we were cruising at 20 hundred rpm, hope you all get out and try it too.
