Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Put on a Airtex 8131 and builds about 9-11 psi when you flip the accessory switch then when started loses all pressure and truck will run for 3-5 min and die. What could be the problem? Thanks
I’m plumbing through the original pump and put a hose that was rated for to be submerged in fuel. And all the air is bled out of system. Once it dies again, I bleed it and it takes awhile for the gauge to come up on the lift pump then once it does I tighten the bleed valve on the sec filter and she fires up again. Idles for 3-5 min and dies
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
