minimalist
- 0
- 0
- texas
I've read the lift pump threads but it's unclear to me how to deal with the piston that has wedged itself to the plate. Do you have to remove the plate to be able to push the piston back up or do you turn the motor by hand? Are the two 10mm bolts the only thing holding the plate on there? I took the old leaking pump out and that's where I'm at.
