Lifting a 809 or 939 with a crane.....
Neophyte
Gentlemen,
I've recently finished a 3 + year refurbish on an old Galion 150A crane. I'm in the final stages of "break in" on all the repairs....and need to do a heavy lift (15 tons). Our trucks weigh just under that, but looking at the lifting points in the rear.........not sure of a good way to get to them (bed on my 925 hangs over as well as my 817).
I assume the the military has a spreader frame they use to get around this, but has anyone ever attempted this without a custom lifting rig?
Thank you
p.s. I'll post pics when I can accomplish this final test
wreckerman893
Possum Connoisseur
15,612
1,984
Yep. I was in an ordnance unit at Fort Benning and we had cranes that would have been used had we deployed to a port for an ammo unload mission.
Each crane had a spreader frame as part of it's Basic Issue Item inventory. One day out of complete boredom I read the TM that came with it and it showed how to rig vehicles to be picked up with that spreader system. They could also be used to pick up 20 and 40 foot shipping containers.
You might could construct a field expedient spreader from heavy chain and thick walled steel pipe. I think I saw that in a TM somewhere (maybe Vehicle Evacuation and Recovery) but memory fails me right now.
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
Rather than tear something up you can always just zip the bed off and set it on the ground and use the leaf points. Taking the bed off is easy when you have a crane. The rest of us have to improvise.
Sent from my SM-G860P using Tapatalk
73m819
314
gainesville, ga.
The 809/939/39 5ts and the deuces get picked with the front lift brackets and the LIFT POINTS between the rear duels, this is the horizontal pin that is straight up from the duels pivoit. They DO NOT get lifted from the rear for a crane pick, you WILL bend the frame.
BigDawg41
Springville NY
I came across this picture when doing Seabee truck research and thought it was pretty cool.I wonder if any hood or front end damage happened? Hope it helps
73m819
314
gainesville, ga.
If they had turned the spreader bars the other direction in line with the truck they could have picked the truck level, a lot safer and better rigging, I am guessing that they are going by the book BUT the book does not no all
Jbulach
2,055
Sunman Indiana
Your going to need a speader no matter where you pick from, except maybe the mirrors...
M925A2 with dump hoist
Jbulach
2,055
Sunman Indiana
On second thought, I guess you can pick from one end only. Fun setting back down!
