Lifting cab
scottmandu
36
Texas
So I have a m1078 with a bad hydro seal which I have ordered. But how can I raise the cab before I replace the seal to address a loose belt issue.
If you have an overhead crane or very tall cherry picker you can life the cab from the rear.. When I did it I disconnected the hydraulic lines to the lift cylinder. It made a mess.
Suprman
696
Stratford/Connecticut
No with a bad piston seal you will still have the hand pump. If there is not enough fluid in the reservoir then the hand pump won't work. There is a small dipstick on the pump the reservoir is part of the air hyd pump.
Suprman
696
A bad pump piston seal will "puff" hydro fluid out of the breather. It will look like little puffs of smoke. Sometimes the 2 hyd lines come loose. If you are standing in the bed, you can reach under the cover plate and feel them they are on the front left of the pump.
bikeman
501
Ft. Bragg, NC
Might help if you take a picture with reference, clear up any confusion about what's coming from where.
turnkey
wadsworth,ill
If all else fails, disconcet the life cyld and manual life with a cherry picker...Guys over at the motor pool, have done it several times...Just make sure everything is removed ...Before the life.
