So, noticed what seemed to be too much play in the rear trunnion bushings (springs a bit cockeyed in the perches on the axles)
no biggie, I knew the U-bolts needed to be changed as well, so I figure tackle it all at once no problemo
managed to get the nuts off the u-bolts but they were so solidly rusted in place no amount of beating was going to get them out
so cut the bolts so that I could lift the pack out, Spring pack won't budge,
My question is, before I start fabricating something to forcefully jam a wedge underneath the spring pack, or pull all the torque-rods so I can spread the axles, do the 2 bolts on either side of the trunnion need to be loosened to remove the spring pack, or are those just there to add stiffness to the casting. It doesn't call out loosening them in the TM, but I figure you all have far more experience dealing with this.
(and yes I prolly need to replace the tired springs as well, but I was hoping not to have to drop 1k on some new springs just yet...)
