Light for Dixson OEM above mounted Tachometer
cg25713
51
New York
Is there a light inside this tachometer? If yes, any ideas on how to fix mine? Mine has the military screw on pin connector only. It looks like this one. Thank you.
Action
1,552
East Tennessee
When you take apart your tach, you will see there is a place for a light bulb to go. But nothing is in it. You may have to pry the edges of the face trim ring to get it apart.
My theory is that the rpm at 55mph in the day will be the same as it is doing 55 mph at night. On the same trip.
