Lights and Flashers issue..
82ABNMP
53
Winston Salem NC
I've got a gremlin somewhere. New headlight switch, new brake light switch, all fuses checked replaced, all bulbs checked replaced, 2 new flashers. Drivers side rear taillight ground checked and cleaned, and the rear light harness ground checked and cleaned.
Problem: When the service light switch is "on" the drivers side rear flasher/signal part of the taillight bulb stays illuminated.
All other lights and turn signals work. BUT the hazard lights will not work/flash
Headlights work high and low, along with front side markers and front parking lights
Passenger side tail light functions correctly.
Ideas? Thanks, David
dougco1
677
Cooperstown NY
still sounds like a bad ground in the rear taillight assembly. Try to install a temporary ground to the frame or a 12 volt power jumper to the flasher. Does the drivers side turn signal work front and back? The flashers will not work if it doesn't sense the proper voltage.
82ABNMP
53
Winston Salem NC
Yep I m with ya on the ground issue. It was the first things i checked. All the turn signals work, front and rear both sides. Except the drivers side rear which stay on, but will flash with the signal turned on. The hazard lights will not flash gut the dash indicators will stay on when the hazard light is engaged. And I don't have brake lights.
Tinstar
1,936
Edmond, Oklahoma
What about the turn signal switch inside the steering column?
I had a bad one for a horn issue than all checked good until I had steering wheel off and looking at the switch.
