Lincoln Welders
5,112
I didn't see any water in the oil, it's still exactly at the full mark and no water showing on the dipstick. The plugs pulled didn't show any rust on them either. I'm hopeful I'll get it unstuck from letting it soak. But if not, I'll rebuild it. Just hope that the cyls would only need a honing at most. I can handle everything but boring here in the shop. (Well that and grinding the crank)
5,112
I finally pulled the head off this week. My worst fears have come true. One cylinder is terribly rusted/scaled. And there's substantial rusting in the valves. So I've decided to source a different engine. While it's not original, I've got a Perkins 3.152 heading my way with the correct flywheel and plate. (I love diesels....) I'm going to get the sandblaster over here at the shop and start pulling the amature off and sandblast it and the frame to get everything ready to paint/swap. I believe I'll go with my plan of using the extra M105 trailer I have here to setup as a welding trailer.
rustystud
3,372
Woodinville, Washington
I always like the Perkins diesel engines. Good sound units ! When I was at IHC several Scout owners had them installed and loved them !
87Nassaublue
Sharpsburg, Ga
Not sure about Lincoln SAE200 welders but I restarted a surplus WWII Hobart welder that had sat in a WVU agricultural engine lab for years. The thing fired up and had a fine voltage control on the end of a cable pigtail. It would make sense that a large welding company would make military welders long ago. Mark
A friend of mine who has since passed had a big old military type hobart welder. That was the best running stick welder I ever used or heard of. I tried to buy it from him but he wouldn't part with it a the time. Sometimes old equipment is the best ever!
