List of semi trailer M numbers and use?
rubicon_in_ga
Covington, GA
There are probably a hundred different models of semi trailers out there. Just wondering if anybody's come across a general list and description of the semi trailers that are at least somewhat common? I've searched the Trailer forum for 'semi' and the GL site and I made a basic list of what I could find, but I'm only up to about 17 different models. So far I have found references to the following:
M119 6T single axle van
M127 stake flatbed
M128 12T van
M129 12T tandem axle van
M131 fuel trailer
M146 6T single axle shop van
M172 25T tandem axle lowboy
M295 gooseneck flatbed
M313 6T tandem axle expandable van
M348 van trailer, offset rear doors?
M373 6T van electronics
M447 6T tandem axle shop van
M749 expandable van
M750 expandable van
M823 10T tandem axle van
M871 22.5T tandem axle flatbed
M971 command trailer
If anybody can point me to a location on the web with a list, or give more specifics on any of the listed models or add to this list, it would be greatly appreciated. I'd like to find intended use, number of axles (tandem or single), and rated tonnage.
Thanks!
D
Deleted member 11142
Guest
m129
M313
m870 40T Tri-Axle
L999here
South Bend,IN
M172 and M172A1...
According to my manual,the M172 lo-boy flat bed trailer was rated at 15-ton and was the same dimentions as the heavier M172A1 25-ton lo-boy. These were both rated for the M113/114 APC's but were 9'7" wide and need a 'wide-load' permit to move 'em. I've got the M172A1 for both my APC and my halftrack....but looking for a smaller 8' wide one specifically for the WW2 halftrack.
