Lister/Onan LPW2/DN2M
Thomas606
Fairbanks, alaska
Have new and used parts for these engines both 2 and 4 cylinder. PM me if you are interested
The thing is fresh out of rebuild shop, just don’t know what direction it is supposed to run, when I hooked up starter w negative ground it turned counter clockwise at the flywheel, not sure if making it positive ground if it will turn opposite direction, have heard a lot of military applications run positive ground,have had mixed answers as to weather or not the starter will turn the other direction, haven’t had time to check it out.
Guyfang
27,146
Burgkunstadt, Germany
I told you in post #20 what directions the engine turns. Your information on the milatary having positive ground systems is wrong. There is no power generation system in service today, nor in the last 40 years that has positive ground. The last gen set to have positive ground that I ever worked on was a Stewart & Stevens, 5200, 400 cycle gen set. Unless you are 65 years old, or older, you haven't seen it.
jamawieb
578
Ripley/TN
dpequip, are you the guys that sell a lot of parts on the big auction site under dpequipment? If so I've bought several high quality OEM parts from you and been very satisfied.
Farmitall
280
Eubank, KY
The starter only engages in one direction, it free wheels in the other. This is why you can hold the starter in after the engine has started and rotating at significant RPM.
These generators push air from the inside to the outside of the case through the radiator. A look at the fan blade pitch will tell you which direction the engine HAS TO TURN for the unit to operate properly.
Also, these engines will not operate in a reverse direction, the timing would never allow it to start, let alone run.
