Salty dog
- 174
- 43
- Spring, Texas
Is there anything different that needs to be done if the M1009 is still the 24v original set up
I was asking in particular to connecting to the battery, if the way they are interconnected would require anything special. I am still new to the cucv and treating everything as a learning experienceIsn't the lighting system a 12v system? I understood that the only parts of the CUCV that were 24v were the things added to meet NATO standards like the slave cable port and communication stuff?
Sent from my SM-G970U using Tapatalk
I've learned the hard way with these, and our FD's CUCV has been modified so that adds a degree of difficulty for me as well.I was asking in particular to connecting to the battery, if the way they are interconnected would require anything special. I am still new to the cucv and treating everything as a learning experience
Wasn't there also some 24v stuff going to the rear bumper for the trailer lighting?Only the starter and glow plug feed are 24 volt. All other parts are 12 volt common to the civy models. All 12 volt supply starts at the diamond shaped junction block on the firewall. This is your 12 volt supply for the relays. The 12 volt switched from the headlight switch triggers the solenoid on the relays, directly connecting the lights to the front battery.
This reduces wire and switch voltage loss. You should use 20 amp auto reset circuit breakers to protect the wires in case of shorts.
Ahh, yes...a little rooting around reminded me it was some of the trailers that had 24v lighting. Mah bad.No, the trailer wiring is all 12 volt.
Trucklite Part Number 27450C |
I brought the same part directly from China,half the price post free , easy to fit ,as for LED headlights refitting these on older vehicles in the U.K. is against the law ,there must be a good reason for this .Is there anything different that needs to be done if the M1009 is still the 24v original set up
Thank you SirShop this part number at your favorite shopping site. They will cost you $350.00 or more more. But again what is your deductible when you hit a deer on the side of the road at night
27450C
