LMTV 3126B Barometric pressure sensor fault code and location
Ronmar
8,401
Port angeles wa
AKA: SAE or BSPP(british standard pipe parallel) type fittings that use a sealing Oring or sealing washer. There is usually a little step or bevel cut around the hole to contain the seal…
hike
—realizing each day
941
Texas Hill Country
After my original ECM died and I purchased a new one from cat and they flashed it to 330 hp I never had it connected to something that could read codes until the other day at cat when they changed my speedometer pulses for the eco hubs.
Thanks guys, So that mystery solved!
Now for a solution. If I put 194-6722 atmospheric pressure sensor on, would the trouble code go away? Would it be recognized by the ECM? Would the ECM like it or confuse it because of the static barometric pressure is programmed in there?
The biggest question is would the engine benefit at all by doing this?
Check this thread before buying? Starting at fifth post by @MatthewWBailey—
