- 2,592
- 6,216
- 113
- Portland, OR
Yeah that's essentially exactly what I posted above. You still need the transducer and charge sensor - whatever those are - and neither lists specifications so you still need to contact Red Dot.
The RD part numbers are included on both schematic and harness details.Yeah that's essentially exactly what I posted above. You still need the transducer and charge sensor - whatever those are - and neither lists specifications so you still need to contact Red Dot.
Do not have them yet.. just did a quick Google to verify the part numbers. My AC work will continue later in February. Part of my LMTV camper build project. The Yeti.Are you able to find those sensors and where did you find them?
It's Christmas! It came early!!Update!
Attempted to connect with RedDot with no success. Turned to MME, where I bought the newer GEN II unit and pleaded with them to request the diagrams from RD.... success! Got the wiring and harness diagrams. Christal Clear! I see the light.
I am including it here so to help all.
Maybe search in here for Duck Bills or duckbill think that may be the drain type used so searching for that may helpI've been sitting on my kit for over two years now. Just moved some of it around & realized I need the little drain plugs & remember reading a thread here on the forum where the part number was shared. I'm at about 2 hours later & didn't find that, but did find some other good information. Seems I have this newer style Gen II kit with the diagnostic module on the side. Thanks to everyone for the input & that .PDF of the wire diagram is going to be a huge help.
Going to have to open up all my stuff, lay it out, & check again to see what, if anything, I'm missing. 2 years ago I checked & thought I was good but I wasn't 100% on the wires.
Any chance anyone has that part number for the drains on the Gen II cab unit?
FYI when I finally do this, I plan to COMPLETELY document it all on my YouTube. It will probably be in 2 or 3 parts as this is going to be a complex install & I know there is going to be issues.
Please let me know if you find them. I see you deal more with the larger parts. If you don't want to deal with 1,000 of them, I may be willing to work a deal with you to buy them all. I sell a lot of small parts for military stuff. I know sometimes when dealing with the big stuff that the small things are a PITA.I have some of the drains, they were very hard to find in quantities less than 1000! Now I need to remember where they are.
