http://s447.photobucket.com/user/deshet1980/library/1996 LMTV
I took a bunch of pictures today.
Quite a few to confirm the mileage
seat belts with new tags.
New Air filter dated July 1996.
Unopened service manuals.
Clean frame
I also took pictures of problems areas.
Looks like I am missing the oil and transmission dip sticks.
The lines to the transmission oil cooler are missing. (confirmed)
Some cannon style connections under the air filter housing are hanging and something seems to be missing
Some electrical connections on the transmission are missing
Most of the transmission bolts have been removed (bolts that connect the engine to the transmission)
Can't raise the cab by cranking the jack arm. (fluid leak)
Looks like most of fluids are drained.
I need to tighten the some bolts allowing the cab to raise
One line to the air dryer has been removed.
I have to trace down a bunch of bolts.
Please look at the pictures and let me know what I need to fix.
I included some pictures of my excursion on 35s" tires with a 6" lift. It isn't much bigger than the excursion but it is larger.
Thanks
