Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Air leaks between filter and tank? Filter sealed well? Drain seated properly? Try talc powder to look for seeping diesel. When I cleaned my fuel system out I heard a check valve/flapper in the tank. Have you tried blowing compressed air down the draw fitting to blow out debris and clear it incase it's leaking there?
Hope you get it. The small stuff is the most annoying. I need to figure out a different battery mod so I don't have to buy those expensive batteries. A reliably starting truck is a necessity.
mine did this too, turns out it was leaking air in the water fuel separator, the rubber diaphragm went south on the hand pump, I was told they all pretty much do it in time, replace the water fuel separator and all is good now
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
