- 3,853
- 3,978
- 113
- Brooklyn, NY
Please post plans in a separate thread.Pretty easy to make any truck manual to demonstrate. The last two of Dave Andersons roundups I went to, I brought a little switch box that has my dead controllers cannon plug and one momentary double throw toggle switch installed. I could plug into anyones CTIS harness And manually control the system. I built it with Control hardwired and the toggle switch manipulated Supply or Deflate. You turned ign on/off to activate/release the control solenoid to seal/vent the PCU… Easy to build if someone has a bad controller with connector kicking around. But be forewarned, using it at the meets, I found leakage on nearly every truck I hooked up to
it was more popular than a Cheerleader at a Dungeons and Dragons convention…
Sorry to hijack
