LMTV throttle cable
Awesomeness
1,519
Orlando, FL
I'm trying to get a custom throttle cable made. Does anyone have one, outside of a truck, that you could give me a couple measurements off of?
I can get to the ends of mine, for things like thread size and length, but can you tell me:
  1. How long is the outer jacket (from any two points you specify, like ends of both threaded ends, or just the black jacket itself without metal fasteners)?
  2. How long is the inner cable (again, from any two points you specify, like the eyelet holes)? Along with this, the question I'm trying to answer is how far does/can it move?
Thanks!
aleigh
53
Phoenix, AZ & Seattle, WA
I dunno but mine is crimped down in the engine by the frame rail and kind of sticky. Have to lift up on the pedal sometimes. Figure it'll wear through one day at WOT and I'll get a big surprise. Item whatever on the glitch list, right after I repair the raptor fences.
scottmandu
36
Texas
Check the linkage that goes to the hand throttle, that can bind sometime.
Awesomeness
1,519
Orlando, FL
I checked just the cable, and it's very gritty sliding in the sheath. Hopefully, someone will have one out of their truck that can grab some dimensions.
S4ndm4nn
22
Germany
​Hey Awesomeness,
i removed the cable from my LMTV because I change the engine, if that is still up to date I can measure that for you.
Please excuse my bad english, but I'm from Germany
:D
