Bought a 2001 LMTV with a 3126 and allison MD3070 transmission. I have two questions. My front seal is leaking in the transmission assuming the input shaft for the torque converter. The only issue is that it puddles on the ground as a white/pink foam. Not sure its water or just foaming up from air. Dip stick fluid looks fine, not sure if I have a bad cooler or not. My other question is How do the FMTV's shift. Mine shifts great and real firm from 2nd to 5th, but 6 and 7 shift good, no flare but I cant feel the shift like the other gears. Just curious if this is normal. Tried to do a test with manual shifting it but it wouldnt let me shift past 5th manually.
