LMTV wheel CTIS on a 5 Ton
charlesmann
713
Temple, Tx
I can answer yes to running wheels, but not leaving the ctis system installed and plumbing into the truck.
i would venture to say yes, by swapping out the banjo fitting inlet hose out for a hose that would work with the a2 plumbing from the hub.
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
A2s use a metal pipe with an O ring where it goes into the drive flange. Why I suggested tapping it and using a hose to connect that tap port with a JIC fitting to the ctis valve the lmtv wheel uses.
They are 55psi valves
