LMTV Winch Harness
Sgthoffer
West Virginia
Hi guys, I bought a winch panel and it came with the harness below. No instructions though. Do you know what plugs in where. I have not had the dash apart yet.
Photos are below.
coachgeo
3,363
North of Cincy OH
Pretty sure this one goes to back of Tach
would you please consider taking good full pics of this harness and note which wire has which number.... and where these pin out on the sockets. Would be awesome to have a POV of pin outs to compare with the wiring diagrams
Sgthoffer
West Virginia
Black connector for tach
Black burndy connectors
White male generic connector
White female generic connector.
I will label using these numbers as I have time to check for continuity with a meter at each plug to figure out where the wiring goes from here.
Sgthoffer
West Virginia
You should be able to source most of these parts to build your own harness using these three images below to locate parts with.
Find the part, as shown above for example part number 18
Part number 18 has a part number as SMS18P-1
If you type that into various websites.. you get a result like the one below.
