Loading your trailer on your hauling trailer
11b1776
Fort Gibson, OK
My location isn't providing any fork truck assistance anymore, anyone have a suggestion on how to load them? A winch is all I can think of but that wont keep the hitch from dragging will it? My trailer doesn't have a winch yet. I maybe making more than one trip unfortunately. Any advice, thanks in advance.
rlwm211
Guilford, NY
If you park your trailer, chock the wheels and also put blocking under the back so it cannot drop, you can back your 'bought' trailers onto the hauling trailer one at a time, if your towing vehicle is big enough to do it.
1,814
What kind of trailers are you loading on what kind of trailer? I've loaded quite a few M101 type trailers with wood and a come-a-long. I've done tons of stuff with a couple of come-a-longs.
rbeasley66
Lakeland, Fl
I've used a winch while loading my trailers. I make a loop with chain from one side of the axle to the other and pull from the center of the chain. With that setup, it makes it easy to steer as the trailer comes up the ramp. The M105's were easier because of the landing gear wheel. The M200's without a landing gear wheel were harder. For those I used a hand truck strapped under the tongue with the hauling foot against the lunette, it worked okay and I could still steer it some to keep it going straight.
I never liked winching it from the lunette, it was hard to steer and it seemed to dig in as it was being pulled up. That's why I prefer to load or unload hooked to the axle.
My experience so far.
rbeasley66
Lakeland, Fl
I don't have the photos on my phone of the recovery of my two M105 trailers with a borrowed two vehicle car hauler.
But this is the gooseneck trailer I have now hauling some M200's home. I have a couple of receiver hitches at the front of the trailer that I can slip my winch into for pulling. It's mounted to a receiver hitch plate and works well like that.
bebobalhan
san jose, nm
Unloading can be "fun" also. A 8000lb come-along from harbor freight is less than $30. I loaded my M105 backward onto the tow trailer. Made unloading easier... I think:roll:
OKCM38CDN
Del City, OK
I haul my m-38CDN and M-100 trailer on a 16 foot utility trailer... what I have done is mount a 2500 lb ATV winch in a box on the tounge of the Utility trailer. Then I placed a piece of steel channel (2" wide by 1/2" deep) up the center of the trailer with the flat down. I load the jeep first then winch the trailer up under the rear of the jeep. I use the lunette as it just follows the channel onto the trailer. Oh, I set the front of the M-100 inot the channel to start...
I do this as 90 % of the time I am loading or unloading alone (My son never seems to make it to dad's to help load)...
Hope this helps...
xiongy
Atlanta
I've used this technique to unload, but am not that confident enough in my backing up abilities to try to load this way.
