Loadstar Deuce Conversion
6point9diesel
MN
Hi fellas. I'm new to the sight. Great place you have here. I've been lurking for a few weeks, trying to learn a few things.
I picked up a Loadstar a few years ago that had been converted to a 6x6. I'm wondering if anyone can help with any information. The conversion was done by a company called the Zeligson Co. I've been told by others that it is some loadstar and some deuce. I've been looking for information on whether the axles are Rockwells or something else. I'm also wondering if the suspension is based on a military setup, or if the conversion company used some other setup?
My plan was to use it for farming/hauling to antique shows, but I've had a heck of time finding time to work on it. Has anyone used a deuce as a tractor trailer setup? Will road speed in one of these be around 50 mph, or can I expect more?
Sorry for all the questions...that's what newbies are for right?
Here's a link to some pictures I have of it:
Loadstar pictures from friends & fun photos on webshots
Thank you for any help or discussion.
Paul
6point9diesel
MN
Thanks fellas! I appreciate the responses. Before I post anymore questions, I'm going to check out the manuals.
Thanks again,
Paul
wreckerman893
Possum Connoisseur
15,618
2,013
That looks like it might have been an Air Force truck.
Install a 5th wheel, air lines, pig tail and work her like a rented mule.
Larger tires/wheels will give you better road speed and fuel milage.
Not a bad looking old Cornbinder.
6point9diesel
MN
Thanks fellas,
I've run the gamut in terms of how to dress it out. I've thought about a fifth wheel, but it doesn't have air brakes. I don't think it would take much to put a dump valve and a compressor on it, then have it DOT'ed.
I've thought about a grain box then hauling a pintle hitch trailer with it. This would make it the most versatile for me. We'll see, I've got a few logs on the fire I need to burn down before I tackle this one. I'd sure appreciate any ideas.
Yeah that drag link is a doozy. I suppose that's why they say you've got to heard the old binders down the road.
Thank you for the comments.
One other question, could anyone point me in the right direction for finding the correct manual for the suspension/axles?
Paul
