Location of return fuel lines from injection pump and under the HMMWV 1152
Lui1152
Maryland
Can anyone help me and tell me where are the return fuel lines at the injection pump and under the hmmwv.
Pictures would help please
Thank you
I need to blow through them..... I might have a clogged return line. I hope
Action
1,555
East Tennessee
The rubber hose comes off the top of the IP and connect to a metal tube. That metal tube also connects to each bank of injectors, and to a rubber hose near the lift pump on the RH side at front of engine (below your a/c compressor). That rubber hose connects to a metal line that runs back along the frame rail to a rubber hose that connects to the fuel tank hard lines (in front of tank). There is a one-way valve in that section of hose.
Lui1152
Maryland
Thank you so much!
I will work on it this weekend.
Hopefully blowing air with a compressor clears the lines.
Monkeyboyarmy
193
Kingsville,Oh.
Thanks for asking this. It's been too cold to work on mine but i noticed a return hose on one injector, that didnt not have a clamp on it, was leaking and if i touched it the truck would idle different. I suspected a clogged return line also. Hmmmm.....said check valve...
Lui1152
Maryland
I am so glad 😊
Whatever keeps these beasts running 💪🏻
Monkeyboyarmy
193
Kingsville,Oh.
Update!.... Took some time to check my truck out. First i removed the hose connection at the frame on the right side where the return tube comes down from the side of the engine. Blew through the return line that goes to the tank and it was clear. Could hear bubbles in the tank. Tried to blow up the metal return tube and had nothing. I removed the return line from the injection pump to the metal return tube and blew in it....nothing. Plugged between the two. So i used compressed air and blew up the line and then down the line until it cleared out. Had black crud and maybe some rust in it. Reconnected all lines and magic! This truck runs fantastic. Starts easy, no surging, no dying after revving up, great throttle response. Apparently the pumps dont like any positive pressure in them. Hope this helps someone out.
Lui1152
Maryland
Could you please take pictures of where all of these lines and tunes are.
I am doing all these tomorrow and have no idea of where to start.
Thank you 🙏
Monkeyboyarmy
193
Kingsville,Oh.
Didnt get a chance to take a picture of my truck yet but this is the tube in question. Its at the front of the engine. In the picture, the right side of the tube connects to the driver's side injector returns. The middle of the tube connects to the top of the injector pump for its return. The left side of the tube connects to the passenger side injector returns and connects to the line that goes back to the tank....right frame rail near the front of the engine. This tube is what was plugged between the pump and passenger side.
