Log of my M1165. Project Joshua.
TOBASH
3,959
Brooklyn, NY
NDT
7,485
Camp Wood/LC, TX
The tire now used is the Baja BF Goodrich…has been for quite some time, that tire I see is a 2017 date coded tire.
RWH if I could kindly ask you to share any and all safety information related to MT/Rs. I was under the impression that this sidewall issue was only for a certain year(s) of mfg, not every single one of them.
Retiredwarhorses
4,606
Brentwood, Calif
Milcommoguy
2,413
Rosamond, CA
This may or MAY NOT be the word or product... so read and determine one's own needs.
HMMWV Goodyear Tire Blow-Outs:
HMMWV and Trailer Caution - Inspection Required
Goodyear Wrangler MT-R tires have a serious problem with premature wear causing multiple blow-outs, including two accidents with injuries.
Inspect these tires: 37x12 50R16 5LT load range D tire, NSN 2610-01-541-4090 (used on tire/wheel assembly, NSN 2530-01-558-2138), and load range E tires, NSN 2610-01-563-8328 (used on tire/wheel assembly, NSN 2530-01-563-8620).
The Goodyear Wrangler MT and Michelin BF Goodrich Baja T/A tires are not affected.
For the affected tires look for the DOT code on the tire sidewall. The last four digits following "DOT" indicate the week and year of manufacture. For example, 2515 means the tire was produced the twenty-fifth week of 2015.
Any of the affected tires that are older than five years, or that will exceed five years before the next scheduled maintenance, must be reported as NMC. They must be replaced even if they appear to be serviceable.
Affected tires that are less than five years old must be inspected for cracks. Pay special attention to the decorative U-channel ribs in the upper sidwalls on both sides of the tire.
Any cracks longer than 3/32nds of an inch make the tire NMC, they must be replaced.
See TACOM SOUM 18-007 at the CAC enabled access of: https://tulsa.tacom.army.mil/Safety/message.cfm.
Peanut butter or jelly or both. CAMO
