Long Manpack Antenna AS-4266A/PRC
Capehenery
Virginia Beach
I have a couple of these Long Manpack Antenna AS-4266A/PRC
5985014257305
80063ASSYA3256530-1
I am assuming they are for the radios that were carried and not for a vehicle.
Can someone fill me in on what it can be used for?
I'm really interested more in one that can be used on my 923A2
I do not have a radio at this time and when I do it will most likely be a handheld HAM radio.
Thoughts? I do not have a clue and I'm just now researching the idea.
mblank
Lawrence,KS
As-4266a/prc
It's for a SINCGARS manpack. Won't fit any of the vehicle antenna bases. 30 to 108 MHz range. http://www.rami.com/product/manpackhandheld/a3256531-1-green/
30 to 88 mHz max 5 watts CW
The AS-4266A/PRC Antenna is an 8 ft. Manpack Antenna for use with portable SINCGARS Radio Systems RT-1439 and RT-1523 or similar system. The antenna is made up of an antenna element consisting of tube sections which can be disassembled when not in use. The antenna element is connected to a spring assembly which in turn is connected to a connector/matching network assembly. A modified BNC connector attaches to the Radio System.
