Looking at hmmwv for tow rig
porkysplace
1,496
mid- michigan
I was looking to find out the weak points so I know what would need to be replaced/upgraded not so I could be told it can't be done
Sent from my Nexus 6 using Tapatalk
It was designed as a tactical vehicle not a tow vehicle . You can gold plate a turd , but you just end up with a expensive turd.
So throw all the money you got at a HMMWV and you still won't have a tow vehicle what does what you expect.
snowtrac nome
140
western alaska
Coming from some one who has some hitch and trailer experience, I would recommend not to do this. you could fab up a class 3 receiver and use an equalizing hitch but as a load carrying I would not recommend it. your front end would be too light with out the equalizer and if you try to balance the load it will push the rig around causing sway. Likewise you will have to have an electric brake system as surge brakes don't play well with equalizers. If you want a military truck than get an lmtv they have all the stopping power you need along with the weight to control the load at high way speeds. I use mine all the time with a car hauler and no trailer brakes and even with a one ton pu on the trailer you don't even know its back there.
tage
69
LOS ANGELES / CALIFORNIA
I’ve got a gooseneck in mine and pull a 28 foot 10 ton trailer loaded with 11 tons of excavator. Pulls no problem. It is a little slow up hill. I ignored all the published military specs and even the testing . Everbody knows the military under rates everything. You can easily multiply by 5 whatever says .
I hope that's satire.
If not. I seriously hope dot gets you.
Edit:
Dot= department of transportation
5,141
It's satire.
For what it's worth, I tried towing a M105 trailer with a comm shelter on it with mine. Let's just say that a trip around the block not even up to highway speeds had me coming back home in a hurry.
Now I have a drash trailer as well that weighs about the same as that other setup and has just as much wind load. My 1038 pulls it fine, just sllooooooow. Course that trailer was meant to be pulled behind a HMMWV.
My point? The HMMWV isn't great for pulling trailers, unless the trailer was designed for the HMMWV, and even then it's not that fun.
ClintA
14
Mule Creek, NM
As we have 2 CUCV's that are used for Ranch trucks and there is a huge difference between haling and towing. You can put on a ton and a half of salt blocks and go anywhere and make good time, you hook it to a 16 foot goose neck trailer and you can walk ahead and get there sooner, then hook it to a 20 foot trailer and your better off unloading your horse and riding from home. Never even sat in a HMMWV but with the same engine I would expect the same results. just my 2 cents.
5,141
Yeah, the HMMWV faces the same lack of power on tap issue as the CUCV. But the suspension adds another variable to the mix that can make things interesting at times.
My 1008 however gets beat like a rented mule. But it handles everything I throw at it. (It also has a turbo) Several people will vouch for extreme towing it's done as seen at the GA rally last year. :patracy:
Quinton
SC
Only problem with the lmtv besides looking like a Mitsubishi on mud tires is no 4 door option without extensive fabrication
Action
1,564
East Tennessee
Private use not subject to DOT rules . I’ve got good trailer brakes so it’s ok.
It is when the combined weight of tow vehicle and trailer exceed a certain weight. Do you have a class A license like you may need? If so, DOT is involved...if not and you should, then DOT should definitely br involved.
Quinton
SC
Well then as far as I have seen on the auctions are these trucks going for 15-20 depending on condition. Is this about average or would it be wise to wait for a different time of year?
BLK HMMWV
566
Pasadena California
Not familiar with your state laws regarding even getting it registered for on highway use.
I'd find out if you can even get licensed for driving on the road first before you spend a nickel.
with that said like someone said earlier stick with an H1.
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
Only if you are involved in INTERSTATE OR INSTRASTATE commerce does DOT matter in some states. If you are hauling your own private property and even 80,000lbs you are not subject to federal or state DOT of your state does not require you to have a cdl
You mean the 10,001 lbs of gross combined weight on a interstate or intrastate commerce vehicle. Private property doesnt fall into that relm
In TN,AR,MS I know for a fact you can be 80,000lbs in a full air brake truck or truck and trailer combo and DOT has no authority over you if you are hauling your own property. They cant inspect you and no scales. You can tell a DOT officer to kick rocks
SETOYOTA
451
georgia
No I put “Not for hire” on both sides. No issues. I’m surprised at how well it does.
tage
69
You're skirting the law on that one. Using the Georgia military vehicle cdl exception.
Assuming you have an A0 is 2,500 lbs, and A2 only 4400 lbs. And you're towing 22,000 lbs + a trailer.
I hope you have have insanely high insurance coverages.
That and you take your rig by a scale house...
tage
69
Cdl aside. Gray area at best. Until the dot officer shuts you down for their interpretation of the law....
Using a hmmwv to tow 22,000 lbs + trailer when it's only rated at 2500 lbs. That is the issue.
porkysplace
1,496
mid- michigan
That's why they drive miles out of their way to go around scales.
SETOYOTA
451
georgia
No I don’t drive around scales . I just go by and don’t stop. It’s all military looking and my own stuff. So no big deal
tage
69
Just because it's your own stuff doesn't make you immune to dot laws.
By making it military looking makes me cringe. I wonder if you wear acu's to complete the look....
You'll get stopped one of these days for blowing a scale...
