Looking for a injection pump for a mep 005a
jmenende
378
Puerto Rico
Sent a pm
Sent from my SM-G973U using Tapatalk
On all the 005 and 006 ive worked on, the first thing that comes off is the IP and gets sent straight to the rebuild shop. All have been rebuilt. Now the issue with these 005 is the crankcase seals leaking oil. Also, change the oil drain valve and hose. Always leaking. Good luck.
Guyfang
23,392
Burgkunstadt, Germany
Should you send it to the rebuild shop, include the repair and testing instructions included in the -34 TM. The military adjustments are a tad different.
jmenende
378
Puerto Rico
You are right about that. The shop i used wanted to set the speed at 1800 rpm and i told them to leave the throttle lever adjustable so that i could adjust the rpm. So its always good to clarify that with the shop beforehand since they are not used to the mil spec settings.
