looking for a pto for a 1973 m35
ssoturbo
mass
i wanna put a hydraulic winch on my m35 any ideas where i can get a pto that i can mount a hydraulic pump to
mudguppy
15
duncan, sc
anything other than the OEM winch drive PTO, it's difficult to find a PTO that bolts to the spicer trans. without knowing more about which trans the 3053 is similar to, it may be impossible to select a compatible PTO from someone like muncie.
otherwise, using the winch PTO to run a hyd pump may be required. if you could find a dual outlet transmission PTO (the one that has a thru-shaft for rear outlet) then you'd have greater flexibility and ease of mounting the hyd pump. or you'll have to get a transfer case PTO and use it to run the pump.
and when all else fails, get an engine-driven clutch pump - this would be the easier to adapt and can be had with large flow/displacement capabilities. they aren't cheap, but neither are PTOs + pump + driveshafts or chains/sprocket + your time.
do you already have the winch or are you adapting hydraulics to an existing winch?
ssoturbo
mass
i have two 20,000 lb hydraulic winches one on the front and one on the rear just trying to figure out the easiest way to run a hydraulic pump off of a pto
m16ty
228
Dickson,TN
Here's some pics of my hyd pump running off of a transfer case PTO.
I'm getting ready to install a hyd pump off of a trans PTO for my uncle. The problem is, the output is facing the wrong way. To get around this (and not wanting to buy a dual output), I'm going to use a chain driving a jackshaft that will send the output beside the PTO and toward the back.
Mudguppy, Chelsea did make a PTO that fit the deuce trans but it has been obsolete for years. You may stumble upon one in a juckyard somewhere but that's about it as far as civilain PTOs go.
