Looking for detailed pictures of level wind
seano11
104
Edmonton Canada
I'll try and get some pics tonight hopefully someone chimes in and tells me the bolt size I'll see if the gf will take some pics of me with the truck in my short shorts
swiss
944
Oakwood, Ga
Bring your socket set with you tonight, it is one of them between 5/8 and 3/4 :)
Don't be using them metric wrench's you have up north, lol
m1010plowboy
2,977
Edmonton, Canada
M813 nut bolt wind size
One day you'll get er' done eh.
Don't know how big your bolt is but here's some of your pictures and our random M1010 M813 convoy video. Might have a pic' of your mechanic. Does she go away when you have these questions? All I know is 2 1/2 ton is half of 5 ton, even when looking through the TM's.:) Good luck
M813 M1010 Canadian Convoy - YouTube
Vintage iron
Falmouth Ma.
see you found a level winder and tensioner. They all need to be torn down and greased. I left one of the wheels out of the tensioner and the cable end slid right through, then put the wheel in.
seano11
104
Edmonton Canada
Ok so I tried to tear down the tensioner and I can't get the rod out that holds the wheel in place I get it almost all the way out then it just bloody stops is there a trick to getting these out or do I need a press ?
73m819
328
gainesville, ga.
MAN, you must have some REAL baggy shorts, or truck is a NEW name for ----,you might want to second guess the the pics if this is the case.
zebedee
conceptualizer at large
894
Central NY
Hmm - I thought my front winch looked wrong! Just released from GL auction, the cable comes up the front of the drum, over the back sharp edge of the level wind frame, over the pulley then down, under the big fairlead roller and out! Cable is not level wound on the drum, all bunched up on one side - all rollers and swivel on trolley siezed (solid grease) and a broken clevis with chain n hook on the back deck under the crane. Cable terminates with a thimble and old style screw and nut clamp (not the "u"bolt kind)
I guess the last user wasn't the smartest.
So - upon tear down - found shiny blue paint all over the level winder - and white on the indexing plate of the tensioner, all under some green. Assuming this is normal for the manufacturer.
