looking for hmmwv half doors.
Robus1022
Pensacola florida
Im looking at my x doors and you would have 3"+ missing if you cut the back door angle vertically. Would have a big hole. The rounded contours are much larger on the front doors. Meaning you would have to cut the front bottom corner to match a much larger radias. Good luck
TedG
39
MI USA
I'll get fresh pricing on these. They would be blanks...no hardware or arm rests. These front doors will sit about 1/4" higher than rears though but it never bothered me.
TedG
39
MI USA
I can get them made for $250 per set = left front door and right front panels. NO hardware, just cnc'd aluminum with all holes. pm me if interested. I will require advanced payment to secure your order for I do not need these. Shipping would be extra.
TedG
39
MI USA
Here are mine when populated. Again, I would only provide the flat door panel. NO hardware or Armrests.
Sorry, I will not be doing the rears.
Retiredwarhorses
4,559
Brentwood, Calif
View attachment 611058View attachment 611059
when I did mine, I had to use a set of rears to get the arm rests and hardware....I have a finished set that only needs paint and stripping...but they ain't cheap. They are a one off.
jake-cutter
13
League City, Texas
I am finding two different types of rear half doors. One appears to be not as wide with a spacer on the hinge side and then the other is normal width. Where does the one with the spacer that is not as wide as the other come from? Any benefits to one over the other?
TedG
39
MI USA
Rear doors: Version 1 is standard door. Version 2 is short for uparmored 1152.
Also, since no one has come forward for fronts panels, I am not going to have them made.
jake-cutter
13
League City, Texas
Is anyone else going to order a set of the fronts? I found the rear half doors and even the rear armored half doors to take parts off of to complete the fronts. These make an excellent alternative to the overpriced X doors.
rarpinz
New Berlin, WI
YES!!!!! I will want to talk to you first but I'm thinking this is what I'll need. Please call me : Bob 262-352-4467
