Honda Power Equipment - Honda Generators - Wattage estimation guide
according to above:
Circular Saw (Heavy Duty, 7 1/4 in.), 2300w start, 1400w steady state
1400watt * 1.10 (for inverter loss) = 1540watts from battery... 1540/12= 128 Amps...
Assuming you have a stock CUCV 12v alternator, it is rated for 100A.... leaving 28 amps drawing from one of your batteries even if you are running your truck... that battery will not last more than about 1.5 hrs even with the truck running (depends on the AH of your battery and its condition) ... and that will be **** on the battery...
If you had a 24V inverter, you could cut the amps in half in the example above... 64Amp draw over both alternators, so you could run your inverter and not discharge the trucks batteries... the wire would be smaller and the strain on the system would be less...
Or in other words If you run your saw one hour using a 12v inverter, you'd would need a 128 AH in batterys... two walmart biggie deep cycle batteries would work... and you would kill them, and have to recharge them... batterys don't like to be fully discharged in an hour and then fully recharged... its hard on them., so they wouldn't last long.
So either get a 24v inverter for the saw, and run everything else off 18V cordless tools, butane nail guns etc... or just buy a small 2300W genny for the cirsaw when working in remote areas?... thats what I did when I was a contractor.
