Looking for vent line diagram
garlar4
Banned
30
-1
st louis
Does any one have a complete vent line diagram for the hmmwv. I am looking to trace all my lines and check them. Would be helpful if I can fine a full diagram for a standard hmmwv.
Thanks in advance.
Sent from my iPhone using Tapatalk Pro
parklandtrans
Roy, wa
I would think that a set of instructions from a deep water fording kit for a HMMWV should be the answer your looking for..?
If I remember correctly that will cover almost if not all of the vent lines used...any input from other members on this one...or am I barking up the wrong tree..??
I will research this and post any and all results I find for you on this thread..!
Bob (parkland Trans)
garlar4
Banned
30
-1
st louis
Thanks guys, I'm not sure why more people have not chimed in here. I did find this though.
gcbennet
Trenton, ON
My RH rear brakes were rubbing and heated to the point where it melted the vent tube crossing above it to the diff. Does anyone have a source for vent line on the market? Kascar sells it but it's not cheap, but I figure there's probably a compatible aftermarket somewhere out there we can use without having to give up our first born.
juanprado
2,905
Metairie/La (N'awlins)
Might not be spec but I often sold plain ole rubber vacuum line to splice hard plastic tubing in my parts day. Cut off clean both pieces where melted and stick a piece of rubber hose over the rigid tubing spanning both pieces. Tie wrap to pull away from trouble area.
Action
1,557
East Tennessee
AMG sells it by the foot, IIRC. If Kascar has a high price, it may be for a roll of it.
fpchief
220
South Alabama
NAPA has it. i just bought some. It seems to be the same stuff. Almost impossible to seat fully up on the barbed fitting.
