Looking to install 5 ton winch
kaiser2help
East Freetown, MA
I have an older M series 5 ton with an identification tag that says m series 5 ton without winch. However, I am looking to put one on. Can anyone tell me besides the winch itself, mounting brackets, and propeller shaft etc, from start to finish what are all the components that I will need to make the install correct and complete. Cranetruck or Floridianson could you help elaborate.? As always any input is greatly appreciated.
73m819
319
gainesville, ga.
Pto, pto control lonkage, drive shaft, frame extensons ( inner/ outer), winch mounting plates, lower winch mounting angles, NEW bolts, AND of course the WINCH
groundog
wittmann,az
:driver:BE SURE TO GET ALL THE BOLTS AND NUTS WITH THE FRAME EXTENSIONS--THEY GET EXPENSIVE---ALSO SHIFT LEVER AND LINKAGE ALONG WITH THE PTO AND GASKETS-I PUT ONE ON MY M-813A1---INSTALL WINCH BUT BEST TO LEAVE BOLTS A LITTLE LOOSE TILL EVERYTHING LINED UP----PTO SHIFT LINKAGE SHOULD BE PRETTY CLOSE IF IT CAME OUT OF A TRUCK BUT YOU WILL PROBABLY HAVE TO ADJUST IT SOME NEW DATA PLATE---GOOD LUCK
