Looking up unit/service history via inventory number
osteo16
570
Evansville, IN
Can one look up unit/service history using a inventory ID number ... USMC M1046a
ummm... Tow Missile configuration humvee.......I don't think that's a unit number.. That a model number for your truck. Look for lettering inside door frame, drivers side. Also other insightful numerical things may be found under spray painted over areas ( sand/remove paint slowly to uncover) But that's just my 2 cents ..
Ocho out
F.A. Duk
31
Michigan
Ocho out
I have the number that was over painted on the hood. Know it’s a USMC vehicle
HoveringHMMWV
985
AL
Look on the driver's side, just above the ID/serial number, and you will probably see a plate/tag labeled TAMCN and it will probably have a co-located universal bar code thingy. TAMCN is Table of Authorized Materiel Control Numbers and is an inventory system. Your TAMCN plate/tag should also match the USMC # on your hood and tailgate. I am not aware of any public way to find a vehicle history with that TAMCN #.
- HoveringHHMWV
DREDnot
434
Phoenix, AZ
What I have heard is that the USMC XXXXXX number is the registration number of the vehicle. Seen on both sides of the hood and on the tailgate.
Ones that have been assigned to a unit/location they receive the Mxxxxx number. Seen on the side of the body beneath the B pillar and on the tailgate.
If you can decode that Mxxxxx number that should tell you where it came from.
