acme66
- 7
- 0
- Plains, Montana
Giving the tour truck its weekly crawl under/over and I found something that I think is alarming and that you might want to check on your own trucks. Better than half of the bolts that held the front and rear spring perches to the frame were not tight, some barely qualified as 'snug'. Only two of the bolts had the look of one that was loose which is why I put a wrench on it in the first place. Once I started checking all of them however... Nuts are 7/8, bolt heads 13/16. If I was closer to the other trucks I would go see if they were loose also. As it is given how everything looked fine but wasn't I thought I would share. In my opinion everyone should check this real quick to make sure it was an anomaly for my truck and not a larger issue.
https://www.youtube.com/watch?v=9fwlXtNdLF0
Ken
Ken
