Lose gas cap
paulfarber
20
Gordon, PA
Hello all.
The gas cap on my deuce is very lose. I was thinking its time to replace the gasket. Found a post on SS, but not one replied.
Don't want to spend the $$ on a new gas cap... anyone have a source for the gasket?
dozer1
13
Sargeant, Minnesota
paufarber,
If all it needs is a gasket, Bobs answer is hard to beat. On my 5 ton there is 2 tanks with a cap each. A new gasket made one like new and the other was still loose. Seems there is like a brass spring washer behind the gasket. If that is collapsed, the new gasket still wont snug up the cap. I just used the old gasket under the new to get me by for now, but the cap is junk. Just something to check. Dean
paulfarber
20
Gordon, PA
Thanks all,
Was hoping for a NAPA part or quick fix.
A $5 gasket becomes $15+ with shipping. :(
I will take the old gasket out and look at the brass washer.
USAFSS-ColdWarrior
Chaplain
6,296
As an alternative, I have had good luck at the local BEARING SHOP finding various O-Rings and Seals & Gaskets. I've not had to mess with the Fuel Tank Cap Seal on our Deuce, but I'm betting that you can find an appropriate off-the-shelf item that would work.
Look in the yellow-pages under BEARINGS. The local supplier is listed as : West Texas Bearing & Supply,
Material Spec SHOULD include resistance to Diesel/Petroleum Products.
