Losing air pressure when put into reverse (M817)
Rebar
St. Louis/Missouri
Sorry about this mundane question, but every time that I shift the M817 into reverse I get the expected little puff of air escape, but every now and then, it is a massive flood of air that continues until I shift out of reverse. Then the next time it is just fine. Weird. None of the other gears do this. What am I doing wrong here?
Thanks for your help here. Trying hard to be worthy of this totally most excellent truck...
Rebar
swbradley1
Modertator
1,652
Dayton, OH
Could be the air valve for reverse is leaking. My old 818 did and I never fixed it. Use search as there are threads that cover that valve.
73m819
319
gainesville, ga.
Either the reverse air valve on the trans OR the shift cylindler on the xcase
