The post indicates you want it free or cheap. Is your truck the Vortec 7.4-liter V8, or a 5.7-liter V8, or a Detroit Diesel 6.5 L V8 and what year? This is about getting 10 new ones. Is it a pressurized cap which should minimize the search a bit. Is it rated a 16psi cap?
If the truck is NSN 2320-01-123-2665 then the General Motors fuel filler neck is P/N 14063325 which is NSN 2590-01-155-7965 so now where did that "special cap go?
The Cap, filler opening is P/N 14063326 which is
NSN 2590-01-155-5063
To buy seems to be unobtainium, so why am I thinking 1 ton diesel chevy pickup here. Trying to find dimensions tto cross reference.
https://www.youtube.com/watch?v=taDKWkphZjs
It is a GM part 14063326.
Stant 78225
Overall Height: 2.725 inches nominal
Style Designator: Threaded type (external)
Outside Diameter: 2.830 inches nominal
Stant says they are available
Part Number 30600-A1 Specification
Part No. : 30600-A1 Manufacturer : Stant Mfg Co Inc Cage : 78225
NSN : 2590-01-155-5063 Description : Cap,Filler Opening
FSC : 2590 Miscellaneous Vehicular Components
In this PDF is 1095 diesel fuel filler caps made by Stant to look thru for the match.
View attachment 716351 for 50 bucks
