- 1,651
- 1,665
- 113
- Nova Laboratories, WA
6.2 gods, lend me your ears...
I got an oil leak...it's been leaking but since I don't drive it much I haven't delved too far into it. We are talking a quart every 100 or so miles. Enough that it's idling there will be a couple drops in 5 mins or so. The oil hasn't been changed because it's been sitting. But I have driven it probably 500 or so miles and the leak hasn't changed and it's been sitting for 2 years and still no change in oil consumption.
I cleaned everything and dumped dye into the crankcase...
Using my black light...
From above, there is nothing visible.. So, that would seem to rule out valve covers..
From below
There is a little bit of oil on the oil filter and around the oil filter mount, and even on the driver side spring. But those are low points, and I didn't check the spring to see if it was oil, I just noticed it was fluorescing under UV light.
So....
Possible issues..
Oil filter or Oil filter mount
Rear main seal (? Isn't that lower than the oil filter?)
Oil cooler lines
Oil pressure sender(?)
I thought the rear main seal was too low and not in an area that would put oil in the area that oil is, please correct me if I'm wrong.
I would also think that oil cooler lines and the rear main seal would get worse as time and mileage accumulates, so it would seem to me that it's not one of those.
That would leave the oil pressure sender and either the oil filter or oil filter mount.
I will be taking it to a shop shortly because I do not have a lot of time to work on it, but I'm trying to get a an educated guess and a consensus of what is most likely wrong.
From below
So....
Possible issues..
Oil cooler lines
