Rifleman
- 2
- 0
- HOT Arizona
Andy, there is a special tool that allows you to slip it in between each lead and the cannon plug. This Enables you to depress the prongs on each lead that locks it into the cannon plug to remove the leads from the plug without doing any damage. If you Goggle cannon plugs you should be able to find a vendor that lists the plugs and leads but also the tool to remove them too, or if you have a Fry's Electronics Store close by where you live you might be able to find the tool there.
