Low air pressure warning buzzer drives me crazy.
1,190
It's not supposed to be subtle, it's supposed to be alarming. It's an alarm.
Your truck does not come close to meeting federal safety standards as it is now. To remove/modify anything that reduces your(and the rest of the world's) safety is simply irresponsible(and foolish).
1,824
Well, i see your points and its probably best to leave it on, but i will probably replace it with a warning that is less obnoxious, but still easily noticeable over the earth shattering sound the deuce makes.
A warning light is a great way to supplement the low air warning buzzer but in no way shape or form should one be used to replace the buzzer. If it's driving you crazy it's doing exactly what it was designed to do. I can say from experience that when you have your hands full negotiating traffic or an obstacle, it would take one heck of a light to get my attention off the road to look at a light. Sometimes it takes only the time to look away at a light to cause catastrophy on the road. Endure the warning buzzer, save a life.
steve6x6x6
Winter Haven, florida
My buzzer did not work on my truck so i bought a new one and installed it and works great. I am going to run a jumper wire from the parking brake light switch to the buzzer so it has double duty. I have a red light on my parking brake and with the brake set and with the red light on I still drove off and burned my parking brake.
rrepik
not here ohio
It's part of the ambience of driving a deuce, kind of a thrill reminder that you aren't driving the family sedan and a great adventure is about to begin!!
quickfarms
25
Orange Junction, CA
That is the same as removing it in the eyes of the cops.
The cops can make you test it at any time.
Youngstown, OH
I was the exact opposite....mine quit working and it took me a few months to figure out the problem to get it working again. It drove me nuts that it didn't work :)
jwaller
19
Columbia, SC
The military has a kit to add a light to the dash. That's very common and I love mine. It goes right in there middle of the gauge cluster or you can put it wherever you like.
TehTDK
42
Denmark
Personally it would annoy the **** out of me everytime I had to start it. Same with the mandatory audible reverse sound. But I would venture as far as permanently disable the buzzer, but more so build in a "trigger" that disables it for 5-10 mins when I start the truck so that it is silent while the truck is idling and heating up, but still sounds if the air vacates the truck while on the road driving etc.
bigboy44
Ava, MO.
Mine is the same way on one of my trucks and when I start it up I am looking for problems. I will correct it asap. I like safety items of that nature, a hard hat with nothing but clear blue sky above your head, now that sucks.
Bob H
167
I almost never hear mine, actually I can only hear it until it builds oil pressure, then I am out of the cab on my pre trip walk around, checking tires & lights and bleeding any moisture out the glad hands.
Even after the walk around, I still let it idle a few minutes to get the turbo warmed up before I jump in.
I did buy the low air light kit, because when it's running 2200 rpm down the road at night I might not be able hear the buzzer over the howl of the LDT465.
& if I drive off one more time with the parking brake on, it's getting a light too!
MG2936
60
Lapeer, Michigan
Nobody has mentioned the obvious, get rid of the air leaks and you will very seldom have to listen to the buzzer. My truck can set for 2 or 3 days and still have over 60 psi so no buzzer. After setting a couple of weeks it will still have 30 psi. so when I start it the buzzer isn't on very long.
welldigger
Benton LA
Your supposed to drain your tanks when your done driving for the day unless you have an air dryer.
welldigger
Benton LA
As long as you get the accumulated water out thats all thats needed. Leaving pressure in the system won't hurt a thing.
