low brake peddle
Barneyszoo
12
Riverside, CA>
I have a quick question about the brakes on my M35 bobber. I presure blead the brakes, the peddle stays up and brakes are good for about a week, but then they go to the floor. I've checked all the wheel cyl and lines and they are dry, how ever there is a small amount of fluid on the outside air pack could this cause the peddle to go down?
Westech
CPL
6,104
206
cow farts, Wisconsin
Any leak can cause a low peddle. It sure sounds like a Master cylinder problem (remember there are two of them in a deuce, one is the Main master and the one the puts fluid to the wheel cylinders that is in the Air pack) with fluid leaking that is where I would start looking.
