Rustyshackelford
- 12
- 18
- Tucson AZ
The low coolant light on my 1009 was intermittently coming on for a while and now it's on permanently. There is plenty of coolant in the radiator and the overflow jug, what causes this? Should I replace the sensor, clean it, or any other super secret tricks I should know about?
ETA: I do know the manual protocol for testing the sensor. Im just looking for experiences or tricks with this issue.
26. COOLANT LIGHT FLICKERING OR WILL NOT TURN OFF
Step 1. Check coolant for proper level. (See TM 9-2320-289-10)
Step 2. Turn key to “RUN” position. Disconnect black/yelIow lead from low coolant sensor
on radiator and touch to any ground.
If light goes out, replace low engine coolant sensor. (See paragraph 3-31)
If light does not go out, perform step 3.
2-69
TM 9-2320-289-20
Table 2-4. Electrical Troubleshooting (Con’t)
MALFUNCTION
TEST OR INSPECTION
CORRECTIVE ACTION
Step 3. Remove low coolant module (located near fuse box).
If light goes out, replace low coolant module.
If light does not go out, trace circuit. (See wiring diagram F-4 or F-6)
2-69
TM 9-2320-289-20
MALFUNCTION
TEST OR INSPECTION
CORRECTIVE ACTION
