OK, so this is live again. Cool. I guess PM me to get on the list, and questions, comments, and concerns go here. I've been busy with work and family stuff the last few days (and personally needed to step away from this project), so I haven't made any real progress on the cards themselves.
Liability concerns: I'm not a business, just a guy. Making these comes out of my hobby budget, and anything I make goes right back into it. If, for some reason, things expand beyond that, cool. Otherwise it's just playing with my toy cars. That means no money lawyers or any of that. When I get into it (hopefully this evening), I'm going to run some tests. Hopefully GM designed it to fail in such a way that it illuminates the light as an alert that something is wrong (that would be the common sense thing to do). I'm going to be making these identical to the original schematics save that I will use modern components and better components where possible and reasonable (it make sense to use a high precision resistor in an application where it's only throwing the circuit on or off) to take advantage of the increased reliability that has come from the past 30 years worth of development.
Kits: I did think of that. It would certainly be a lot easier for me, that's for sure! I don't think the automotive enthusiast crowd is typically the sort to be packing the sort of setup or knowledge base to do that sort of thing though... I don't have any problem putting loose components in a bag though I guess... Be warned, however, I intend to use small surface mount type components where possible. The reason mine failed was that the wire leads all corroded; surface mount components eliminate that potential point of failure and tend to have better connections from losing the legs, and are generally more robust in settings with lots of vibration, and are less prone to electromagnetic interference (for those so disposed), are smaller (in case we're able to figure out any cool new features and decide to implement them, we'll have more space for them), and they're less expensive (less initial investment for me, lower cost for everyone else). Some of these components are seriously small though (just got my glasses prescription updated, so I shouldn't have any issues), and a magnifying glass and tweezers will almost assuredly prove absolutely necessary. If you're still interested in a DIY kit, let me know. I'll post photos and such when I get the components lined up, and you can gauge your interest at that point.
