- 10,350
- 75
- 48
- Meadows of Dan, Virginia
One feature of my dual tank control panel is the "Fuel Flow" indicator.
It is controlled by a couple of relays and a low fuel pressure switch in such a way that it turns on when the in-tank fuel pump and the return fuel don't match OR if the fuel pressure is low.
Today while doing some crane work the "Fuel Flow" warning light came on. The pump in the main tank was used and the return flow was routed to it (they match), so that ment that the fuel pressure was low (less than 5 psi).
I checked the fuel level and it was low, about 2 inches on the dip stick. I added biodiesel and the "Fuel Flow" indicator turned off when the fuel level was about 3 inches on the stick.
This means that a low fuel pressure switch installed before the primary filter may be used as a "Low Fuel" dummy warning light.
Images below show the control panel with the "Fuel Flow" light and the fuel pressure switch used.
The fuel pressure switch is another "gift" from Kenny in Florida and has NSN # 5930-01-161-9580. It is normally used on the M923 series 5-ton trucks.
