Low/no oil pressure
charlesmann
713
Temple, Tx
Months ago, i noticed my oil psi was getting low according to the gauge. After months of not running, Yesterday, i started it up and noticed the psi at 0, but would start climbing, the more throttle i gave it.
Today, after finishing up the new muffler delete instal, i fired it up and the oil psi gauge was fluctuating then to 0. I messed with the wire at the sending unit, which i thought bc it came off easy, maybe that was the issue. But after tightening the terminal, i then had 0 psi no matter rpm. I installed a mech gauge and i was showing 60ish + psi.
Do these sending units just take a crap or could it be in the wiring? Do any of ya’ll have a p/n for a sending unit from a box store parts house?
charlesmann
713
Temple, Tx
They are junk and all known to be inaccurate.
Stewart Warner 279A sender
Napa 7012374
I would go with a Detroit diesel VDO mechanical gauge.
Many thanks. I went to advance auto a d got the mechanical just to troubleshoot. $20 is a lot cheaper than $5000 for an overhaul on the suspicion it was a sender, and not the oil pump.
simp5782
Feo, Fuerte y Formal
9,342
Mason, TN
Wes, where do you get the parker pushlok fittings and hose? Can you buy that at a local parts store, or do you get it online?
Go to Hufco in Conroe.
You need
-1/8NPT to #4 male JIC x 2
-#4 female JIC to 1/4" hose barb push lok × 2
- 5ft of 1/4" pushlok hose.
-1/8 pipe female bushing or 1/4 female to 1/8 female reducer bushing. Depending on what the gauge end is. It can be 1/4 or 1/8"
frank8003
4,984
Ft. Lauderdale, Florida
Whatever internal combustion engine I ever have had I look at the oil pressure first, no pressure than shut her down. Can spin bearings on no pressure. Then it cost much labor and lots of money.
Oil pressure FIRST.
Deuce1/2
Virginia
Just use parker pushlok fittings and hose with JIC on the block and gauge side.
I have the same oil pressure gauge issue, fluctuating and down to "0" at idle. What about dial lighting with the Detroit Diesel mechanical gauge? Does this work with our 24v systems? Any info helps. Thanks.
