LOW OIL PRESSURE SOLVED!!
mbwarner
Milton-Freewater Orygun (NE)
:D Kudos, oh wisemen of the forum. I hooked up a Sunpro gauge, and sure enough, I had 64 psi at cold idle, not the 30 shown on the dash gauge. As some speculated, it's a 120 pound sender and 60 pound gauge.
I put the 120 pound sender back in, and until I find a NOS 120 pound gauge to stick in the cluster, I'll just figure I have roughly twice the indicated pressure.
Thanks, everybody! :D :D :D
bigelk50
13
albany, Or
So I have a question, When I turn on my master switch my oil psi gauge jumps to 15psi. With the engine OFF!!! any one know why that is? I like what was said above about the 120 sending unit and gauge, I will look into that cause I know the engine was changed out in mine.
DanMartin
Hillsboro, Oregon (USA)
Bad ground? Bad connection to the sender? I would check that stuff first.
bigelk50
13
albany, Or
Wow i never thought of the pre lube. I am new to these trucks. It very well could have one. It only takes about three seconds to come up to normal operating psi. I know what the pre lube looks like, I will check tomorrow as well as the connections Thanks!!
mbwarner
What's a prelube, and what's it look like? I'm pretty uncomfortable running zero oil pressure for ten seconds or so.
For the MF intelligent, is this delay caused by oil draining from the filter canisters, which need to be refilled upon starting, that causes the delay? If so, is there a way/place to install a check valve?
Just thinkin', ya know?
bigelk50
13
albany, Or
sprucemt
14
Warrensburg NY
Already thought out.Check this classified ad.
http://steelsoldiers.com/modules.php?op=modload&name=PN_zClassifieds&file=detail&cat=4&de=984
The filters have the check valve and retain the oil. 3 seconds to oil pressure.
bigelk50
13
albany, Or
Thats a good link. I have those on my fuel primary and two oil filters. I just didi not know that they had a check valve on them cause it was on the truck when I bought it.
nickd
37
Newport, Delaware
JT's spin on oil filter adapters work great and they are simple to install. I bought one of the first sets and wrote the article on them in Military Vehicles Magazine.
littlebob
26
Baton Rouge LA
Anyway to tell the two apart? Mine startsat about 30 cold and goes down from there.
1500m on depot rebuilld, but sat a while
littlebob
jatonka
87
Ephratah, New York
I can't help you with a preluber, but I can supply the spin-on adaptors with anti drain back filters that are designed for the Multifuel engines. JT
