Low power culprit?
Jakob
Louisville, KY
When I first got my truck, it was a runner for a non-turbo engine. I could easily hold 55mph on all but about a 10% grade. A few problems hit me at once and the Deuce was in pieces for about a year. Now that I have it together again, it can hardly get out of it's own way. Forget 55mph, I'm lucky if I can hold it at 45mph on flat ground. What are some of the things to look for? I tried a search, but didn't get any real answers... unless I wasn't using the right words.
Could the in-tank pump be the culprit?
MWMULES
344
DESOTO, KANSAS
They will run without the in-tank pump. Sounds more like fuel filters or air in the lines.
Jakob
Louisville, KY
I changed all three filters already and the fuel in the tank is new. I put additive in the old fuel to "freshen" it up before I drove it the first time.
jatonka
57
Ephratah, New York
I think the timing is critical on these engines, and correct valve adjustment helps some also. I know it's a pain to adjust the timing, but I think it is what makes the difference in "A Runner" and "Won't get out of it's own way" JT out
Jakob
Louisville, KY
Is that something that can get out of adjustment on its own?
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
How many times have you had it out, and for how long since its been back together? These trucks like long hard drives(sounds like some ex-girlfriends too). If you only took it around the block, get her out and runnit! Is runnit a word? Anyway go for a drive, if just to put a smile on your face, it always works for me.
1,168
That explains why their your ex's!
If you can't run with the big dogs, stay on the porch!:oops:
Jakob
Louisville, KY
The first couple of times, it was just down the road and back. The last time I had it out was quite a trip, probably 45 miles one way and back. A combination of highway and back roads driving. That is when I really started getting concerned.
