Low Range and Reverse
G744
3,703
Hidden Valley, Az
Ball hitches are nonsense, pintle hooks and lunettes rule.
I've seen twice where ball hitches failed, causing a lot of problems.
Military pintle jobs just don't fail.
Besides, it keeps others from wanting to borrow your trailers.
biscuitwhistler37
769
Michigan
I agree, but I had the ball hitch trailers long before I had the truck. It's a 20k Curt commercial, not a bad unit 😎
canadacountry
405
Canada
@HDN what you just said sounds like the particular drivetrain in the volkswagen iltis, apparently I've at least once heard about of that it was really part-time 4wd but with how weak the shafts were it was "advised" to only ever use 2wd mode for making tight turns on dry hard surfaces but to leave it in 4wd any other times otherwise
  • Like
Reactions: HDN
HDN
4,923
Finger Lakes Region, NY
I've read about Jeeps with the manual transfer case getting the driveline bound-up when driving on pavement with part-time 4WD engaged. That happened to my mom's Grand Cherokee once when she was having trouble making smooth turns going to the office one day. My dad was on the phone with her and instructed her to find an empty parking lot and drive the Jeep in reverse and in an S-pattern to release tension in the driveline, then shift the transfer case to 2WD.
I'm sure the same thing happens with anything with manual transfer cases. I think most of us are probably careful enough driving our trucks to keep that from happening - take it out of 4WD or 6WD or 8WD when you don't need it anymore :p
